when I building hello-mod (fio) ,an error occurred,below is the error message. QorIQ-SDK-V1.3.2-20130325-yocto/build_p2041rdb_release/tmp/sysroots/i686-linux/usr/libexec/ppce500mc-fsl-linux/gcc/powerpc-fsl-linux/4.6.2/ld:cannot find -laio how to solve this error,help me please
解決済! 解決策の投稿を見る。
Hello XunXun,
SDK 1.6 has already integrated the package "fio" in meta-oe/meta-oe/recipes-benchmark.
I attached the recipe for you, please use it directly or modify your recipe based on it.
Yiping Wang
Hello XunXun,
Probably you missed some dependence packages, please kindly provide your build procedure and the error log.
Yiping Wang
hello Yiping
thank you for your reply
"log.do_compile.txt" is the error log file.
I used the "hello-mod" as the template to compile "fio-2.1.4.tar.bz2"
I changed all files in "hello-mod\files" ,then modified the content of file "hello-mod_0.1.bb"
then I excuted the command "bitbake hello-mod"
Hello XunXun,
Yiping Wang
According to the method you provided, I solved the problem
thank you
