I accidentally clicked "debug TED-kit", then it can't connect to TED-kit2 tool. How to fix this problem? (initialisation of ted-kit 2 with serial number "ah035ywx" failed. this tedkit 2 box cannot be used and is not shown in the hardware view.)
I can fix it
Hello @mednassim .
In order to better service for you. Would you please kindly describe your detail information in English?
Have a nice day!
hello @fangfang
Hello @mednassim
Thanks for your information.
For the TED-Kit2 problem you could reinstalled the software and tested it again.
Hope it help you.
In my case this same issue is came.
@fangfang whichever solution you had provide like reinstall the software.
but still its not working.
If you have any solution please provide us.
please find attachment for your reference.
怎样修复
我的邮箱:wxf-5555@163.com,我在苏州
你在哪边?方便把东西寄过来处理吗?
已经解决了,谢谢你。可以把盒子拆掉,里面板子有J-LINK接口,我是通过J-LINK接口然后把firmware文件里的十六进制文件给烧录进去的,然后就没问题了。
对的,是这样的!你们是用在哪方面了?
