By any chance are you using a MIFARE classic ? If that is the case, could you please help me checking the example NfcrdlibEx4_MIFAREClassic in the NXP NFC Reader Library.
Estephania
Estephania
Using NXP library can correctly pass the authentication, but it is too big to be transplanted to my MCU, so Now I am writing the driver code by myself. I have successfully obtained SAK, but the authentication is not passed. I can't find the problem by comparing with NXP library
