The compiler used in this project is WindRiver, interrupt cannot be entered. Can you help to solve it?
In addition, I found the root cause of this problem is startup.s, interrupt vector is not registered. I took simulation, and the state of the register is correct, as shown as in the figure.
Since the MCAL driver doesn't register the interrupts, you have to register the interrupts manually.
Nam
Hi:Nam
I have the same problem, how should I egister the interrupts manually? Can you give me an example of the above question. Thank you very much!
