Can the shunt resistor on BAT+ in 33772b be moved to BAT+?
Hi Wenfeng,
I am not sure I understand your question, could you please share more info about your planned configuration?
Keep in mind that the operating voltage of ISENSE is the following:
Vinc is the operating input voltage for ISENSE+ and ISENSE- terminals.
Vind is the operating input voltage difference between ISENSE+ and ISENSE- terminals.
Tomas
thank you.
I have confirmed that I cannot move the Isense pin to the bat+.This is because Vsense is only 2.5V
