Dear NXP fellows,
By looking at the S32 SDK for SJA1110 RTM 1.0.2 documentation, it lists the following Debug Probes as compatible:
• Lauterbach TRACE32 JTAG Debugger
• P&E Multilink (with P&E GDB Server)
However, here we only have the S32 Debug Probe available.
Is it possible to use the S32 Debug Probe for debugging the SJA1110 through the S32 Design Studio?
Thank you for the support,
Guilherme
Solved! Go to Solution.
HI, S32 Debug Probe supports following devices only:
