After I install CodeWarrior in my Ubuntu-8.10, When I run cwide, it will be exception,
the error message as following:
$./cwide
[: 241: closing paren expected
gcc: 4.1.2.
/cwide: 241: Bad substitution
Btw, CodeWarrior Version: CWX-MGT-LLAPP-EX Rev. D
Lot #111408-4009
How to solve the problem? Thanks for any help!
Hi, you might want to post in the section for 'other' processors / solutions. This section is for the MQX RToS.
Good luck with it.
