Hello, I am trying to use the BATT-6EMULATOR to emulate a battery pack to determine BMS functionality. Can this module be used to simulate a charging battery (i.e. sinking current instead of sourcing current)?
Thanks.
Hello Matt,
I hope all is great with you.
In this case, the BATT-6EMULATOR board can emulate a multi-cell battery pack that can be easily hooked-up to the evaluation boards for MC33771 and MC33772 battery cell controllers (BCC):
Therefore, as long as the features mentioned before (from FRDM33772BTPLEVB or FRDM33772BSPIEVB) are useful for you, the BATT-6EMULATOR is a great option.
I hope this information helps.
David
