how to switch from SL1 to SL3 for Mifare plus x card on CLRC663 chip?
As you might know, there are some of the documents and libraries which are under NDA (Non-Disclosure Agreement) and placed in DocStore, could you please follow this guides?
Docstore tutorial part 1: User Registration|NXP
Docstore tutorial part 2: portal usage|NXP
Also, you will need to contact one of our distributors available in the Distributor Network|NXP to help you through the NDA process.
Estephania
which command can i use ?first auth(0x70)?following auth(0x76)? how can i use these commands?
now my mifare plus x card is SL1 status!!!
