Hi.
I have a question about PN5180.
In datasheet, There isn't IO pin ratings at The Limiting value.
All VIL is 0V at The Characteristics. Do I need to follow this?
Isn't it acceptable for minus tens of mV?
Thank you anyway.
Solved! Go to Solution.
Hi Shiori Sugawara,
The data sheet specifies the VILs to 0V, so I think better follow the spec, otherwise you have to take your own risk.
Kan
Hi, Thank you for your advice.
Sorry, That's not the answer I was looking for.
I'd like to know minimum limit.
Many IC chips can apply a minimum limit of -0.3V.
I think that PN5180 also can apply -0.3V, but I can't find it.
Hi Shiori Sugawara,
Kan
Hi Shiori,
I am not sure which version of data sheet you are referring to, but the latest version has the data you are looking for, for example,
Please kindly refer to https://www.nxp.com/docs/en/data-sheet/PN5180A0XX-C1-C2.pdf and https://www.nxp.com/docs/en/data-sheet/PN5180A0XX-C3.pdf for more details.
Hope that helps,
Kan
