Is there a way to get OM29263ADK PCB files (Altium)? or gerbers?
1,891件の閲覧回数
marc_new
My customer is asking that I duplicate the small 4 turn 20x20mm antenna on the PCB I am laying out for him - I was just curious if there is a way to get the digital files for that particular structure. I appreciate any assistance given.
Thanks in advance
1,611件の閲覧回数
Kan_Li
I have the design files , please create a private ticket via http://nxpcommunity.force.com/community/CommunityContextPage , then I may send it to you thru that channel.
Thanks for your patience!
Kan
10 返答(返信)
1,611件の閲覧回数
marc_new
Kan,
Thank you - I created a ticket as requested -
MO03Desi996096
I appreciate the support
1,611件の閲覧回数
Kan_Li
Marc,
Just sent , please check it on your side.
Hope that helps,
Kan
1,611件の閲覧回数
markfreeman
Kan,
Altium files for the OM29263ADK (the large antenna, in my case) would save me time creating a similar antenna.  What steps shall I take to obtain them?
Mark
1,611件の閲覧回数
Kan_Li
Hello Mark,
Please kindly refer to How to submit a new question for NXP Support for details.
Kan
1,612件の閲覧回数
Kan_Li
Kan
930件の閲覧回数
Akhil_Puranik
Hi @Kan_Li
I tried to create a private ticket via
http://nxpcommunity.force.com/community/CommunityContextPage but the link is having some issue.
Can you please help me in gettig the Altium file for the same.My client also wants me to use the same in his project.
886件の閲覧回数
Kan_Li
Hi @Akhil_Puranik ,
Please submit a private ticket via the Case Portal according to the following video:
https://www.nxp.com/video/tutorial-for-nxp-support-case-portal:NCP-VIDEO .
Kan
1,611件の閲覧回数
qizhou
Hi Kan,
I have created a case with 00278508, can you help share the layout file with me?
Qizhou
1,611件の閲覧回数
anmol_workmails
Hi Kan,
I came to you for help regrading footprint for antenna on OM29263ADK 4turns 20x20mm.Due to size issue i need to use this antenna with PN7150 chip.i ll appreciate if you can be of support.
my case id is 00227368.( I use Altium designing software)
Anmol
1,611件の閲覧回数
mawaist
Hi Kan,
I just found this post while looking for OM29263ADK altium files to get the PCB files for smaller antenna. We are going to integrate MFRC522 in our system, due to space constraint I would like to use the small form-factor (4 turn 20x20mm) antenna.
I have already created the case (Case:00209254). Please help us to provide the Altium files for this antenna. I will be looking forward to your assistance.
Muhammad Awais
