PMC Control - How to wake from VLPS from CAN? Also, VLPS mode still has a current draw of over mA?
523 次查看
Poley
Contributor V
Hi all,
Firstly how do you wake from VLPS from CAN traffic starting? I tried to set an interrupt on the same pin as CAN but it does not let me build due to the pin being used in multiple cases. What is the best way of implementing this?
Also, when putting the device into VLPS mode there is more than uA of current draw. Is there something that also needs to be switched off to lower the consumtion as I saw that there is a 30uA consumption on the example given on a nother post.
Thanks!
0 回复数
