When I do code generation in the MBDT, [ “C:/Freescle/"CW" is not the internal or external command] appears
What's wrong with it?
Solved! Go to Solution.
Hi,Daniel
I have solve the problem by your suggestion, thank you very much!!
在 2017-07-11 16:26:10,"dumitru-daniel.popa" <admin@community.nxp.com> 写道:
NXP Community
You have been mentioned
by dumitru-daniel.popain Re: MBDT code generation problem in NXP Community - View dumitru-daniel.popa's reference to you
Hi Jiang Feng,
Your problem seems to be similar with this one: https://community.nxp.com/message/905868?commentID=905868#comment-905868
It looks like your operation system does not take into consideration the paths that contains spaces.
You may even reinstall the CW IDE in a path without any spaces or you could enable the 8dot3 mode on that partition.
Hope it helps!
Participate in the conversation by replying to this email |
This email was sent by NXP Community because you are a registered user.
You may unsubscribe instantly from NXP Community, or adjust email frequency in your email preferences
Hi jiangfeng,
Hope it helps!
Hi,Daniel
NXP Community
Hi Jiang Feng,
Hope it helps!
