Continus reset wiht S32K3X4EVB-T172 in MBDT
ferminzafira
All the programs I load on the card use Model base design tool box to make the reset LED blink. The only parameter I touch is the configuration of the board in Matlab, which does not appear S32K3X4EVB-T172 and I put S32K3X4EVB-Q172. I do not know what could be the reason, I have not changed any jumpers position.
thank
dragostoma
Hi, @ferminzafira,
Thank you for your interest into Model-Based Design Toolbox for S32K3.
It looks like your evaluation board enters into a sequential reset state. Please review the following thread  S32K3X4EVB-T172 with MBD which addresses the same issue. The J31 jumper position might be incorrect.
Let us know if your problem persists.
Dragos
dragostoma
Hi, @ferminzafira,
Dragos
