We are using MQX 4.2.0 on a Kinetis MK64FX512VDC12.
I am trying to know which interruption is triggered by an action.
To do so, as a test, I installed a custom default ISR just before the action. My ISR is called but I cannot find how to get the interrupt ID (or vector if I understand correclty) from the ISR itself.
_int_install_default_isr takes a INT_ISR_FPTR as a parameter, which is defined as
typedef void (_CODE_PTR_ INT_ISR_FPTR)(void *);
From what I understand, the pointer we get as a parameter would be the one given with the custom ISR, if I had set it using _int_install_isr for example. If so, no information related to the current interruption should be available there.
Is there any way, from an ISR, to know what interrupt it is currently reacting to?
Rudy
解決済! 解決策の投稿を見る。
Hi Rudy:
I would suggest you refer to function _int_unexpected_isr (mqx/source/psp/cortex_m/int_unx.c)
I hope it helps.
void _int_unexpected_isr
void *parameter
{ /* Body */
KERNEL_DATA_STRUCT_PTR kernel_data;
TD_STRUCT_PTR td_ptr;
_GET_KERNEL_DATA(kernel_data);
td_ptr = kernel_data->ACTIVE_PTR;
#if 0
#if !MQX_LITE_VERSION_NUMBER
uint32_t psp, msp, i;
printf("\n\r*** UNHANDLED INTERRUPT ***\n\r");
printf("Vector #: 0x%02x Task Id: 0x%0x Td_ptr 0x%x\n\r",
(uint32_t)parameter, (uint32_t)td_ptr->TASK_ID, (uint32_t)td_ptr);
psp = __get_PSP();
msp = __get_MSP();
printf("PC: 0x%08x LR: 0x%08x PSP: 0x%08x MSP: 0x%08x PSR: 0x%08x\n\r", __get_PC(), __get_LR(), psp, msp, __get_PSR());
printf("\n\r\n\rMemory dump:\n\r");
for (i = 0; i < 32; i += 4) {
printf("0x%08x : 0x%08x 0x%08x 0x%08x 0x%08x\n\r", psp + i * 4, ((uint32_t*)psp)[i], ((uint32_t*)psp)[i + 1], ((uint32_t*)psp)[i + 2], ((uint32_t*)psp)[i + 3]);
printf("0x%08x : 0x%08x 0x%08x 0x%08x 0x%08x\n\r", msp + i * 4, ((uint32_t*)msp)[i], ((uint32_t*)msp)[i + 1], ((uint32_t*)msp)[i + 2], ((uint32_t*)msp)[i + 3]);
#endif
#endif
_INT_DISABLE();
if (td_ptr->STATE != UNHANDLED_INT_BLOCKED) {
td_ptr->STATE = UNHANDLED_INT_BLOCKED;
td_ptr->INFO = (_mqx_uint)parameter;
_QUEUE_UNLINK(td_ptr);
} /* Endif */
_INT_ENABLE();
Hi Rudy:
I hope it helps.
void *parameter
{ /* Body */
#if 0
psp = __get_PSP();
msp = __get_MSP();
#endif
#endif
_INT_DISABLE();
} /* Endif */
_INT_ENABLE();
Hi Daniel,
Based on _int_unexpected_isr, I got what I needed!
Thanks a lot!
Rudy
