Is there a method to install multiple versions of MQX?
911件の閲覧回数
keno
I'm presently using MQX 4.1 and would like to migrate a project to the latest version MQX 4.1.1.
Is it possible to install the latest version without overwriting the previous version?  I'd like to compile the project with the new version and perform some testing on it before I commit to changing it over.
3 返答(返信)
728件の閲覧回数
soledad
Hi Ken Overly,
In my experience, you can rename the current MQX folder, when you install the new version of MQX, a new folder is created. To return to the previous version you can simply delete the new folder and to give back the old folder to the original name.
Sol
728件の閲覧回数
keno
Sol,
Thanks for your reply.  It is a little cumbersome but I'm following your method and renaming the installation folder depending on which MQX version I want to use.
Thanks!
728件の閲覧回数
Teckna
Contributor V
Hi Ken,
You can even modify the MQX_ROOT_DIR variable in the project options, without renaming the folders.
Teckna
