Does MQX 4.0 support configuring a UART for 7 data bits, odd parity?
1,276 次查看
gorakk
Has anyone been able to configure for 7 data bits odd parity?
7 data bits, odd parity is required for operation with some existing equipment.
After reading through the RM and reading some answers on this site I thought I could use IO_IOCTL_SERIAL_SET_DATA_BITS to set for 8-bit mode (for 7 data bits and 1 parity bit)  and IO_IOCTL_SERIAL_SET_PARITY to set parity to IO_SERIAL_PARITY_ODD.  But - when trying to communicate with a port set like this, a PC terminal program shows garbage characters.
Stepping through the MQX code shows that in _kuart_polled_ioctl() - setting ODD parity also sets 9-bit mode: sci_ptr->C1 |= UART_C1_M_MASK;
The IO_IOCTL_SERIAL_SET_PARITY case from _kuart_polled_ioctl():
      case IO_IOCTL_SERIAL_SET_PARITY:
         switch (*param_ptr) {
            case IO_SERIAL_PARITY_NONE:
               /* disable parity only if enabled (once) */
               if (sci_ptr->C1 & UART_C1_PE_MASK)
                  sci_ptr->C1 &= (~ (UART_C1_PE_MASK | UART_C1_PT_MASK));
                  /* disable parity bit */
                  if (sci_ptr->C4 & UART_C4_M10_MASK)
                     sci_ptr->C4 &= (~ UART_C4_M10_MASK);
                  else
                     sci_ptr->C1 &= (~ UART_C1_M_MASK);
               break;
            case IO_SERIAL_PARITY_ODD:
               /* can't enable parity in 2 stop bits mode */
               if (IO_SERIAL_STOP_BITS_1 != (io_info_ptr->FLAGS & IO_SERIAL_STOP_BITS_1))
                  return MQX_INVALID_CONFIGURATION;
               /* if parity already enabled, just set the requested one */
                  sci_ptr->C1 |= UART_C1_PT_MASK;
               else
                  /* enable odd parity */
                  sci_ptr->C1 |= (UART_C1_PE_MASK | UART_C1_PT_MASK);
                  /* enable parity bit */
                  if (sci_ptr->C1 & UART_C1_M_MASK)
                     sci_ptr->C4 |= UART_C4_M10_MASK;
                  else
               break;
            case IO_SERIAL_PARITY_EVEN:
                  sci_ptr->C1 &= (~ UART_C1_PT_MASK);
               else
                  /* enable even parity */
                  sci_ptr->C1 |= UART_C1_PE_MASK;
                  else
               break;
            default:
               return MQX_INVALID_PARAMETER;
         break;
/* Message was edited by: Martin Kojtal */
Use C++ highlighter ( https://community.freescale.com/docs/DOC-94815). Thank you, c0170
671 次查看
c0170
Senior Contributor III
Hello Allen Johnson-Weltzin,
have you check what configurations does your kinetis support?
I checked code and RM. Both seem to support 8 and 9 bit data bits plus parity. Not 7 data bits and parity. (RM - 51.4.4 Data format (non ISO-7816)  from Kinetis k60).
c0170
672 次查看
c0170
c0170
671 次查看
gorakk
Thanks for the help, Martin.
What I wound up doing is, when 7-even or 7-odd is needed, set for 8-bit mode and then manually set the most significant bit of the character being transmitted.  For characters being received in 7-even or 7-odd I simply clear the most significant bit.
Also, thanks for the tip on code formatting in posts.
Allen
