hello
Now the mcu I is using is MPC5744. I want to know how to use the srx to receive data via interrupt and not use the sdk, because the example only contains the mode via DMA, so where I can find the mode that I use the the srx to receive data via interrupt and not use the sdk.
Thank you
you can refer to
https://www.nxp.com/docs/en/application-note/AN4856.pdf
https://www.nxp.com/docs/en/application-note-software/AN4856SW.zip
BR, Petr
