Hello everyone,
When I looked at the RM to understand eSCI hardware and its relationship with DMA, I perceived that I should set TXDMA bit in CR2 register after configuring eSCI and DMA. However, I could not recognize when DMA will transfer data from system memory to SDR register.
Could you inform me about that?
Sincerely.
Solved! Go to Solution.
Table 4-5. "eDMA_A channel request allocation" gives requesting source.
BR, Petr
BR, Petr
