When I run the SPC5746R program with S32DS For Power, I get an error.When i View Disassenbly.It point to "0x11c41c6".What should i do for this?
When the circuit is powered on, the software can be downloaded and run. However, after downloading the program, the circuit is powered off and restarted, and the program does not run.
It seems like you are missing source for that part of code in your debug session.
usually helps simple recompile of project. You can also try to clean generated files and regenerate.
Peter
