TGN2-0054-30-36 Motor Data sheet
3,588 次查看
alimeraj
Can someone please help me with the TGN2-0054-30-36 motor data sheet. This motor is used in  MCSPTR2A5775E development kit. I have 2 of these kit however I cant find the motor data sheet anywhere. I need the motor parameters to design my control system.
Ali
3,546 次查看
lukaszadrapa
See please attachment, that's what I got from them.
Hope it helps.
Lukas
8 回复数
3,584 次查看
lukaszadrapa
3,581 次查看
alimeraj
Hi Lukas,
Thanks for sending the links.
I have one more motor that came with NXP kit which is bit different to TGN2-0054-30-36 and I cant seems to find the motor parameter for TGT2-0032-30-24 in the links you sent me. could you please point me where I can find the motor parameters for this motor.
Ali
3,565 次查看
lukaszadrapa
Hi Ali,
I can't find details on their site too. I have only these numbers for the motor:
0.32Nm, 30V, 5.2A, 3000rpm
If it is not sufficient, please send them an email and request more details: info@tgdrives.cz
Lukas
3,560 次查看
alimeraj
Thanks for looking Lukas,
I need inductance, resistance and BEMF value for my control. I don't have RLC meter otherwise I would have measure it. I tried to contact tgdrive but they never contacted back. I was thinking if you guys have any direct contact with them since your kits have their motors?
Ali
3,555 次查看
lukaszadrapa
Hmm, I do not have direct contact but let me try to ask them. Maybe I will have more luck.
Lukas
3,553 次查看
alimeraj
Thanks Lukas, really appreciated.
3,547 次查看
lukaszadrapa
Hope it helps.
Lukas
3,543 次查看
alimeraj
Hi Lukas,
This is great, this is exactly what I was looking for.
Thank you very much.
Kind Regards,
Ali
