Not getting the terminals to connect the board across the relay
Prasad100
 Not getting the outlet pins to connect the board across the relay as shown in the figure attached.
We are using MPC5744P board but not able to find the pins as well as the sensing circuit which is connected to BCC
petervlna
Brian is right.
You should check schematics closely to see assigned pins.
Peter
electron_wrangler
Check out sheet 6 of that reference schematic between the blocks labeled "Relay Sensing Measurement" and "High Voltage Side Connector". The connections are made on the white connector (J3).
