I have general question about FCCU in MPC5777M... In documents for this micro there is an example of configuring FCCU (MPC574xP - FCCU configuration guide) It's not exactly for this particular micro. So here are the questions:
1. Is the FCCU HW Unit in MPC5777M the same as the one from example (MPC574xP) If not what would be the main difference? Any registers to be aware of, any tricky configuration step?
2. Or maybe you will have similar example for micro I work with?
Jozef
