MPC5748G lauterbach debugger software install
Mustafa123
Good morning please i try to install lauter bach debugger   from
help -> install new software -> add    (then show me a window)
                      then i put    name: lauter bach debugger
but it showed could not find http://www.lauterbach.com/eclipse
S32 DS  version 2.1
again thank you very much for your time and help
rweiss
Contributor V
The URL is still valid. Please try again, maybe it was a temporary problem. If you still can not access the URL, then it is more likely that S32DS does not have internet access. Please check your proxy settings.
