DCF Records BOOTCFG1 Configuration
1,053 次查看
KarlS
Hi everyone,
I'm curious if there is a way to enable/ disable the external BOOTCFG1 pin within the DCF Records. This is the same pin that can force the processor to enter serial boot mode when the value for BOOTCFG1 is set from 00 (internal boot) to 01 (serial boot).
Sincerely,
Karl
1,008 次查看
petervlna
No, there is no such possibility to configure BOOTCFG via DCF record.
Peter
1,041 次查看
petervlna
For what microcontroller is this question?
All available DCF configurations are always described in reference manual.
Peter
1,028 次查看
KarlS
Hi Peter,
This would be for the MPC5777C microcontroller.
Thank you,
Karl
1,009 次查看
petervlna
Peter
