Example MPC5676R-eQADCA_STAC_timestamp_eTPUC CW210
* Detailed Description:
* Initializes eQADC module and cyclically converts internal channel 145 (PMC
* band gap). It also configures eTPUC and its timebases (TCR1) to feed STAC bus
* (SRV1). This timebase is used for timestamp of the ADC conversion result.
* Both values (result and timestamp) are displayed in the terminal window.
* No external connection required excluding terminal via eSCI.
* Test HW: XPC567XKIT516 - MPC567xADAT516 Rev.D, MPC567XEVBFXMB Rev.C
* MCU: PPC5676RDMVY1 3N23A
* Terminal: 19200-8-no parity-1 stop bit-no flow control on eSCI_A
* Fsys: 180MHz
* Debugger: Lauterbach Trace32
* PeMicro USB-ML-PPCNEXUS
* Target: RAM, internal_FLASH
* EVB connection: default
附件
%3CLINGO-SUB%20id%3D%22lingo-sub-1291402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20MPC5676R-eQADCA_STAC_timestamp_eTPUC%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1291402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CPRE%20translate%3D%22no%22%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20Initializes%20eQADC%20module%20and%20cyclically%20converts%20internal%20channel%20145%20(PMC%3CBR%20%2F%3E*%20band%20gap).%20It%20also%20configures%20eTPUC%20and%20its%20timebases%20(TCR1)%20to%20feed%20STAC%20bus%3CBR%20%2F%3E*%20(SRV1).%20This%20timebase%20is%20used%20for%20timestamp%20of%20the%20ADC%20conversion%20result.%3CBR%20%2F%3E*%20Both%20values%20(result%20and%20timestamp)%20are%20displayed%20in%20the%20terminal%20window.%3CBR%20%2F%3E*%20No%20external%20connection%20required%20excluding%20terminal%20via%20eSCI.%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%20XPC567XKIT516%20-%20MPC567xADAT516%20Rev.D%2C%20MPC567XEVBFXMB%20Rev.C%3CBR%20%2F%3E*%20MCU%3A%20PPC5676RDMVY1%203N23A%3CBR%20%2F%3E*%20Terminal%3A%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3CBR%20%2F%3E*%20Fsys%3A%20180MHz%3CBR%20%2F%3E*%20Debugger%3A%20Lauterbach%20Trace32%3CBR%20%2F%3E*%20PeMicro%20USB-ML-PPCNEXUS%3CBR%20%2F%3E*%20Target%3A%20RAM%2C%20internal_FLASH%3CBR%20%2F%3E*%20EVB%20connection%3A%20default%3CBR%20%2F%3E********************************************************************************%3C%2FPRE%3E%0A%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎06-11-2021 05:58 AM
更新人:
