Hi NXP,
Need information on i.MX RT1180 Crossover MCU that supports zephyr RTOS :
Does these support IPMI (Intelligent Platform Management Interface) ?
Solved! Go to Solution.
Hi @saiakhil ,
In fact, I also support the kinetis for several years.
But, I didn't find any IPMI information or demos, do you find any related information?
Kerry
Hi Kerry,
Sorry for troubling you again, need information on the (K10P81M100SF2V2).
Is this IPMI available in any of this k series MCU's (or) particularly on K10P81M100SF2V2 as this have the freeRTOS.
Can you please check?
Hi @saiakhil ,
Kerry
Hi @saiakhil ,
You can check this one:
https://www.elma.com/-/media/products/products-files/datasheet-ipmi-controller-axie-atca-cpci.pdf
Seems from the 3rd part which is used the kinetis K10, you can contact 3rd part about the IPMI software.
In the NXP side, I didn't find the IPMI software, thanks a lot for your udnerstanding.
Kerry
Hi @saiakhil ,
Thanks so much for your patience.
I already checked internally, and get the reply:
1. RT1180 Zephyr support still not avaiable until now.
2. The IPMI is from the zephyr, right? to the RT1180, we still don't have the directly IPMI related example.
I just find IPMI related to the zephyr in this github:
https://github.com/nsfcac/Automating-the-scale-up-process-in-OpenHPC
Wish it helps you.
If you still have question about it, please kindly let me know
Kerry
Hi @saiakhil ,
In fact, until now, I didn't find the IPMI in the RT11XX.
Kerry
Hi @saiakhil ,
Thank you for your interest in the NXP MIMXRT product, I would like to provide service for you.
I will help you to check it internally at first, please keep patient, any updated information, I will let you know.
Kerry
