Hi XuZhang, thank you for your quick answer
I tried many times your propossal, but it didn't worked. Everytime I try, the same message appears: "ROM entered ISP command handling loop. Re-enable the debug access".
I tried to erase it directly in command line, but same issue happens:
Is there another way to recover this uC?
