the library files for a metering application to develop in a Keil/ARM environment are not included in the SDK (12.2) as described in the documentation. Does somebody know where i can find it?
there was an issue generating the SDK. It's working now. Thanks
Hi @im-wr
Could you give me more information, please? which board are you using? and how did you build the SDK?
Miguel.
