Hello
I am using the device #KW38 EVB
When I test with two example code; <heart rate sensor>,<blood pressure sensor>, I found some difference of SCAN result.
(I tested with SAMSUNG Galaxy Note 9 phone)
Using <blood pressure sensor> , the [Device Name] in host is always [NXP_BPS]. Exaclty I expected.
BUT, Using <heart rate sensor> , the [Device Name] in host is always [N/A]. I expected [NXP_HRS].
I have No idea what makes this diffence. Anybody can explain this and how to fix the fault scanning result?
解決済! 解決策の投稿を見る。
Did you modify the source code of any of those examples?
What is the android version of your android device? Can you test these applications with a newer android version?
You mention that you tested other projects, and the same issue occurs, could you please confirm if you observed this behavior using the IoT Toolbox App?
Eduardo.
Hello @JungkyuHan1
Hope you are doing well.
What SDK version are you using? Please try using the latest SDK version.
By any chance, did you modify the source code of any of those examples?
Have you previously paired the FRDM-KW38 with your mobile device (perhaps using another BLE example project)? If so, please try removing the Bluetooth pairing data/paired devices from your mobile device.
Also, could you please confirm if the same behavior is observed using the IoT Toolbox App?
Eduardo.
Eduardo.
