Problem with debugging on NHS3100
ソリューションへジャンプ
5,182件の閲覧回数
rado__99
I am trying to debug my NHS3100 via LPC-Link2 with LPCXpresso IDE, but when I'm trying to download the code, the IDE cannot recognize the board.
I don't face that problem with FlashMagic, but I cannot debug with it.
タグ(1)
5,101件の閲覧回数
mario_castaneda
Hi Radoslav,
Possibly the LPC-Link2 board still contains the debugger firmware from Flash Magic. That one is incompatible with the debugger firmware LPCXpresso uses/expects. Can you power-cycle the board and try again?
Also, be sure to read:
  • <SDK>/docs/UM_NHS31xx_GettingStarted.pdf
  • <SDK>/docs/firmware.html > SW Debug Considerations
Please let me know your findings.
Mario
2 返答(返信)
5,101件の閲覧回数
mario_castaneda
Hi Radoslav,
Mario
5,101件の閲覧回数
rado__99
Hello Mario,
The problem were from wrong driver, the Link2 was recognized simply as COM port, not as debugging tool. After uninstalling it and restarting the Windows 10, the correct one was installed automatically.
Thank you for your suggestion.
Radoslav.
