Link external static lib to section / location
1,763件の閲覧回数
martinkoehler
Hello everybody,
I need to bring the constant part (mainly text, preferably also rodata) to RAM but my "normal" code text needs to stay in SPIFI flash. Having tried some ideas with the linker script (disabled the managed linker script file and changed it) and googling around I found no solution for me (except adding the section to use to every function in the lib which is impracticable).
Martin Koehler
1,628件の閲覧回数
lpcxpresso_supp
See the MCUXpresso IDE v10.1 User Guide, Chapter 14, "Memory Configuration and Linker Scripts", and in particular - section 14.11.1, "Relocating code from FLASH to RAM, subsection "Relocating particular libraries into RAM".
MCUXpresso IDE Support
