Hello.
I'm trying to capture I/Q values using the dma_capture API.
It is worked when set start_trigger to FSK_PREAMBLE_FOUND, TSM_RX_DIG_EN.
But not worked when set to FSK_AA_MATCH.
It is on progress with the reference in the following procedure.
Can you give me some advice?
(MKW36A512RM-reference-manual, 1700 p)
Sorry but we do not have an example that enables what you are trying to do as it is up to each customer to implement their own algorithm and we only provide the guide you are mentioning and some of the IQ captures API's.
Sorry for the inconveniences this might cause you.
Estephania
