I am currently programming/experimenting with a PN5180 chip through this board: https://www.amazon.com/Rakstore-PN5180-Sensor-ISO15693-Frequency/dp/B09G2KXPRL/ref=asc_df_B09G2KXPRL...
There is an NXP NFC Library which contains an example program for HCE for Tag 4 Type NFC Tags. This allows the interactions between the reader and a mobile device. However, this requires one of the NXP boards to run the program. Is it possible to run this on another program? I am currently using an Adafruit dev kit and Arduino (Would I be able to take the c files in source and run those?).
HCE_T4T demo is working with LPC1769 by default. The PN5180 NFC library can be ported to other host MCU by yourself. Sorry we don't try this demo on Arduino.
