Hi all,
I'm working with kinetis ROM bootloader, and I want to set the pins to defined state when bootloader is running.
Is it possible?
After reset and enter in Bootloader, what is the pin state? (The default value show in datasheet?)
Thanks for your time and support
Jordi
解決済! 解決策の投稿を見る。
Hi Jing,
ok, so as a summary:
When enter in ROM bootloader (from API or from reset) all pins change to default value excepts the used pins for bootloader. Those pins related with peripheral set via BCA, will be configured as show in 23.1.1.
Is it correct?
Jordi
Hi Jordi,
1. After system reset, the hardware will read FOPT first. If you can't accept ROM bootloader pin config, you can disable ROM bootloader and use flash base bootloader.
2. ROM bootloader will check BCA. You can disable any of the peripherals in BCA. If the peripherals is disabled, ROM bootloader will not set that pin.
3. You can't let ROM bootloader set pins to the state you want.
4. If the pins is not used by ROM bootloader, it will keep in default state. Please see chapter 34.2.1.
Jing
Hi Jing,
thanks for the feedback.
And if I enter to ROM bootloader via API, the bootloader modify the pins? Go to default value? Or maintains the state?
On other hand, ROM bootloader make any change in Watchdog configuration?
Jordi
You can refer to Flash bootloader. It won't reset all the pins. But of course it will change watchdog configuration. In fact, runBootloader will call a system reset. Please look at the bootloader_user_entry() in bl_user_entry.c
Jing
Hi Jing,
I'm using ROM bootloader, I don't have access to any source.
I checked document " Kinetis Bootloader v1.2.0 Reference Manual" and it doesn't show any reference about pins or watchdog.
What is the bootloader_user_entry() method? Is it of ROM bootloader?
Jordi
KE18F ROM bootloader is not opened to customer. But you can refer to other kinetis devices flash base bootloader. They are mostly common.
Jing
Hi Jing,
thanks for your feedback, but I'm using ROM bootloader, and I can not change to another bootloader.
My questions are always about ROM bootloader:
- What is the state of pins when start ROM bootloader?
- When go to bootloader via API, the pins state is changed? Or only change the related with peripherals?
I read the document "KInetis Bootloader v1.2.0 Reference Manual" and "Kinetis KE1xF Sub-Family Reference
Manual", and I didn't find detailed information about pin states in bootloader.
Is there any other documentation?
Jordi
You can keep using ROM bootloader, or you can skip ROM bootloader and use Flash base bootloader. That's fine.
1. What is the state of pins when start ROM bootloader?
If the pins is not used by ROM bootloader, it will reset to default state. The default state is described in chapter 34.2.1 in RM.
2. When go to bootloader via API, the pins state is changed? Or only change the related with peripherals?
Yes, all the pins are changed to default state. Those pins used by bootloader will be changed to the state in page 565 in RM.
Jing
Hi Jing,
About question 1, ok. I found the table of pins.
But, about question 2 In page 565 of RM I can't see any reference about pins.
I attached a snapshot of page 565.
Jordi
Hi Jordi,
Oh, my RM version is really old.
This is a copy for my version. Please see according page in your RM.
Jing
Hi Jing,
Is it correct?
Jordi
Hi Jordi,
Yes.
Jing
