When programming layerscape CPU with Code warrior programmer is native JTAG used or is the protocol SWD? I need to know wether JTAG TDI connection is required or not.
best regards,
Tom
Solved! Go to Solution.
Does the codewarrior programmer for layerscape with 10-pin arm debug connector only support JTAG or also SWD?
Which processor is in question?
Have you read the processor Design Checklist document?
It is for LS1043A CPU, i see nothing about SWD in checklist/reference manual so i guess it's not supported.
We will just implement the 10-pin JTAG connector.
Correct.
Only JTAG functions of signals are used.
The request is not clear.
TDI is essential JTAG signal.
