LSDK21.08 LS1043AQDS QSGMII LAN8814
771件の閲覧回数
SpringMelon
Hello,Wang.In ls1043aqds, first I removed the ethernet@e4000 node (rgmii1), but the error was not found. However, several other qsgmii interfaces I defined also reported the same error. I'm depressed. Files related to the device tree are attached.
@yipingwang
7 返答(返信)
742件の閲覧回数
yipingwang
Discussing with the AE team.
712件の閲覧回数
SpringMelon
Hello,Wang.Could you tell me how to check this problem that fsl_dpa soc:fsl,dpaa:ethernet@0: of_find_device_by_node(ethernet@e0000) failed.
711件の閲覧回数
yipingwang
It seems that there is hardware problem that the QSGMII Ethernet ports cannot be probed in both u-boot and Linux Kernel at all.
699件の閲覧回数
SpringMelon
If I only need the kernel boot network port to be available, I don't need to modify it in uboot.
680件の閲覧回数
yipingwang
You can do MDIO tests on u-boot to examine the LAN8814 hardware first. Use mdio or mii commands on u-boot to read the PHY registers of LAN8814. If LAN8814 doesn't respond with reasonable values at MDIO transactions, it shall have some hardware issues.
=>mdio read  mdio@fc000 0x8 1
For all "F" result, it means there is problem with PHY hardware.
677件の閲覧回数
yipingwang
In your RCW configuration, you configured SRDS_PLL_REF_CLK_SEL_S1=0, please check whether the following is suitable for your target board.
SerDes 1, PLL1 : 0 - 100MHz for SGMII and PCIe
723件の閲覧回数
SpringMelon
How can I get it ?
