Can I interface ls1046 with MT53D1024M32D4DT-046 DDR4.Datasheet is attached below. If possible, 1) 1) how data lines should be connected
2) can I connect this with ls1046 since it doesn't have ECC.
Solved! Go to Solution.
MT53D1024M32D4DT-046 is an LPDDR4/LPDDR4X SDRAM. LS1046A only supports DDR4 and does not support LPDDR4/4X.
Can you please suggest a DDR4 for me to use?
Thank you for the reply. So I am not able to use it, right?
