Hardware break point
386件の閲覧回数
lpcware
Content originally posted in LPCWare by affonpign on Wed Oct 05 19:54:41 MST 2011
Hello everybody,
How can I set a hardware break point in the LPCXpresso IDE?
affonpign
2 返答(返信)
363件の閲覧回数
lpcware
Content originally posted in LPCWare by affonpign on Wed Oct 12 02:19:57 MST 2011
Can you explain then how it works. You say that if I add a blue dot breakpoint in the IDE a hardware breakpoint is set. I can set a lot of blue dot breakpoints and I do not think that the uC has so many of them.
Thanks for your help
affonpign
363件の閲覧回数
lpcware
Content originally posted in LPCWare by CodeRedSupport on Thu Oct 06 00:36:11 MST 2011
If your code is in flash, then LPCXpresso IDE will automatically use a hardware breakpoint.
CodeRedSupport.
