PLU pin in the expansion connectors (lpcxpresso55s69)
900件の閲覧回数
randa_zarrouk
Checking the schematic of the lpcxpresso55s69 dev board, I coudn't find all the PLU_IN1 in the expansion connectors. Any idea?
ラベル(2)
826件の閲覧回数
xiangjun_rong
Hi, Randa,
From the user manual of LPC55S69, we see that the PLU_IN1 is multiplexed with PIO0_14, which is the node of FC1_I2C_SCL, so the PIO0_14/PLU_IN1 pin is connected to pin11 and pin12 of P19 connector.
Hope it can help you
XiangJun Rong
2 返答(返信)
827件の閲覧回数
xiangjun_rong
Hi, Randa,
XiangJun Rong
826件の閲覧回数
randa_zarrouk
Hello again!
Last time your answer was helpful, I thought maybe this time you can help me to find out how can I trigger the PLU_IN2.
Actually PLU_IN2 is either driven through the pin 8 or pin 80 (see screenshot below)
Now, from the LPC55S69_Board_Shematic_RevA1 we can see that pin 8 is multiplexed with SDO_CARD_DET which can be found on the board in P21 (one of the SD card readers I assume) and U20 (which is a component). While pin 80 is multiplexed with USB1_PortPWR which can be found in U18  (which is a component).
Conclusion: no possibility to drive the PLU_IN2 neither from outside the dev. board nor from within.
Any idea how can I make use of PLU_IN2 ?
Thank you in advance!
