Lpc54018 SPI Config
Lpc54018 SPI Config
924件の閲覧回数
Sukumar_M
I Working on LPC54018-EVK . i should config spi on this Board. The first pulse of clock
Width should be high(On+Off =width of first pulse).And The Spi Ssel0 How can be enable.
4 返答(返信)
874件の閲覧回数
Sukumar_M
Thanks for Support to me.
904件の閲覧回数
Sukumar_M
Thanks, I configured but 0xff and 0x7f data's Should be send but this times always data High .
902件の閲覧回数
ZhangJennie
How did you configure the code?
Besides, how does it work if you use this solution ?
https://community.nxp.com/t5/LPC-Microcontrollers/LPC55S69-SPI%E9%80%9A%E4%BF%A1/m-p/1417923#M47974
916件の閲覧回数
ZhangJennie
In order to enable ssel0, we need:
1. config ssel0 pin in pin config tool. for example (this screenshot is from LPC55s69, but same for your device)
after generate code, new pin_mux.c will  include ssel0 pin initialization code
step 2. set TXSSEL0_N FIFO write data register to select ssel0 spi device.
Hope this will help you
Jun Zhang
