LPC18S37 evaluation board
haulam
I want to use LPC18S37 chip for AES hardware encryption and USB Mass Storage + SD Card .
Do we have any EVK have all that features ?
brendonslade
LPCXpresso18S37 demo board:
https://www.nxp.com/demoboard/om13076
then add the SD card using the general purpose shield:
https://www.nxp.com/demoboard/om13082
jmccabe
However, if it doesn't work, make sure to check for a solution on here related to the SD card connector wiring on the OM13082; on at least some,  if not all, OM13082s the VCC pin on the SD card socket isn't connected to a power source.
John
