LPC11U67 changing the FLASHCFG - FLASHTIM more than once
757 次查看
mattiadell_oca
Dear All,
I need to change the FLASHCFG register while my program is running. Is it possible or I have to set it once?
I'm using a LPC11U67.
Mattia Dell'Oca
标签 (3)
标记 (2)
565 次查看
Dezheng_Tang
If you want to raise the CPU clock, make the FLASHTIM value bigger first, then switch the clock to higher speed. If you want to lower the CPU clock, switch the clock to slower clock first, then make the FLASHTIM value smaller.
As long as you follow this order, everything should be fine.
