LPC驱动1024*768屏幕显示水波纹
874 次查看
saidadiao
使用LPC1788的MPU,驱动1024*768的24位TFT屏幕,LCD时钟为19.2M的时候,屏幕显示图像正常,但有水波纹,频闪现象,LCD时钟为32M的时候,屏幕频闪现象消失,但是出现花屏现象,屏幕撕裂
7 回复数
849 次查看
846 次查看
saidadiao
我想知道,LPC1788支持的1024*768分辨率,32位屏的最大LCD时钟频率是多少
819 次查看
Hello @saidadiao
Are your sure 32 bits? Or 24 bits?
And do you want to know the max clock source of LPC1788 LCD clock frequency or your LCD frame?
You can send the datasheet of LCD to me.
Alice
813 次查看
saidadiao
刚回复了屏的规格书,屏颜色深度是24bit的
736 次查看
Hello @saidadiao
1) From the DS of LCD you send, the frequency is out of the LPC1788 support:
2) Please check the configuration of your LCD driver:
HSW HFP HBP VSW VFP VBP
Alice
715 次查看
saidadiao
谢谢,问题已经解决了
814 次查看
saidadiao
