Hello Yan
What kind of build tools are you using?
For CodeWarrior, please refer to:
https://mcuoneclipse.com/2012/02/13/make-my-make-with-eclipse-and-mcu10/
For KDS, user can also find the make file under the project folder, and use the similar resolution.
For GNU build tool chain, you may refer to:
http://gnuarmeclipse.github.io/advanced/headless-builds/
http://www.gnu.org/software/make/manual/make.html
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
Hello Yan
Best Regards
Fiona Kuang
