请问有MKL27Z64VLH4型号,关于makefile的资料吗?
Search instead for
yanandren
对于MKL27Z64VLH4型号的板子,想要使用makefile的工程编译下载,请问有什么资料吗?  链接文件、内存分布等。
另外请问下载位置是从0x0开始的吗?
TICS_Fiona
Hello Yan
What kind of build tools are you using?
For CodeWarrior, please refer to:
https://mcuoneclipse.com/2012/02/13/make-my-make-with-eclipse-and-mcu10/
For KDS, user can also find the make file under the project folder, and use the similar resolution.
For GNU build tool chain, you may refer to:
http://gnuarmeclipse.github.io/advanced/headless-builds/
http://www.gnu.org/software/make/manual/make.html
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
TICS_Fiona
Hello Yan
Best Regards
Fiona Kuang
ivadorazinova
Hi YAN.
Please, can you describe you issue deeper?
What exactly do you find? What KSDK do you use ?
Thank you!
Iva
