对于MKL27Z64VLH4型号的板子,想要使用makefile的工程编译下载,请问有什么资料吗? 链接文件、内存分布等。
另外请问下载位置是从0x0开始的吗?
Solved! Go to Solution.
Hello Yan
What kind of build tools are you using?
For CodeWarrior, please refer to:
https://mcuoneclipse.com/2012/02/13/make-my-make-with-eclipse-and-mcu10/
For KDS, user can also find the make file under the project folder, and use the similar resolution.
For GNU build tool chain, you may refer to:
http://gnuarmeclipse.github.io/advanced/headless-builds/
http://www.gnu.org/software/make/manual/make.html
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
Hello Yan
Best Regards
Fiona Kuang
Hi YAN.
Please, can you describe you issue deeper?
What exactly do you find? What KSDK do you use ?
Thank you!
Iva
