What is the memory map for the 64KB SRAM version of the MKW31Z256
929 次查看
microfirm
The reference manual only describes how the 128KB SRAM is divided up
835 次查看
mario_castaneda
Hi Frank,
You can take a look to the linker file
/* Specify the memory areas */
MEMORY
   m_interrupts (RX) : ORIGIN = 0x00000000, LENGTH = 0x00000200
   m_flash_config (RX) : ORIGIN = 0x00000400, LENGTH = 0x00000010
   m_text (RX) : ORIGIN = 0x00000410, LENGTH = 0x0003FBF0
   m_data (RW) : ORIGIN = 0x1FFFC000, LENGTH = 0x00010000
So, you will have a origin address 0x1FFF_C000 to 0x2000_C000
Hope it helps,
Mario
