I am using MKE15Z series MCU. As per datasheet the default value of WDOG_CS should be 0x2980 but what obtained is 0x420 which is incorrect. But with CMSIS-DAP getting the correct value.
Is it related to debugger. If yes, is there any workaround for this.
Solved! Go to Solution.
Hi MithileshKumar,
Did you try to read the value of WDOG_CS through code? Check if the value is the same as the debugger register view?
If you still have problems after updating the J-Link software, it is recommended to submit a technical service request to SEGGER.
Robin
Hi MithileshKumar,
Robin
