Dear NXP team,
Our customer wants to use "MKL02Z32VFG4".
The package is "QFN 16-pin" and the document is available from the following.
https://www.nxp.com/docs/en/package-information/98ASA00525D.pdf
The customer has started designing the board, but I would like information on the recommended pad dimensions for the board side of this package.
Yasushi Hasegawa
Solved! Go to Solution.
Hi Yasushi,
Please check the following document that provides assembly guidelines for QFN packages.
https://www.nxp.com/docs/en/application-note/AN1902.pdf
Hope it helps!
Felipe
Hi Yasushi,
Hope it helps!
Felipe
Dear Felipe-san,
Thank you for your answer.
Yasushi Hasegawa
